[Qgis-user] Printed map scale question
Sarah Gregg lynkosmail at gmail.com
Mon May 9 08:12:39 PDT 2016
I've run some tests and you're quite right, playing with the paper size and
scale gives me exactly the right result. Many, many thanks to you all (as
ever), Sarah.
2016-05-09 11:10 GMT+02:00 Joris Hintjens <jorishin at gmail.com>:
> In the print composer, you should see the panel “layout”, if not: g too
> View>panels>layout. There you can change the paper size. (eg A0 instead of
> A4).
> gives you a larger working area.
> This
> hope this is what you needed.
> Joris
> Op 6 mei 2016, om 13:49 heeft Sarah Gregg <lynkosmail at gmail.com> het
> volgende geschreven:
> Here I am back again with what may well be a very simple question (though
> perhaps with a negative answer).
> I have digitalised a zoning map on a 1:25,000 base (for Italian readers,
> IGM 1:25,000). So far so good. Now I have to render the results in a
> clearly legible high resolution image for printing.
> To display the full map on the screen, I have to set the scale at
> 1:185.000 and obviously if I create an image file at this scale using the
> Composer, even if I set the resolution high, the base map is scarsely
> legible.
> Is there any way I can get an image of the whole map at, say, 1:75000...
> apart from creating a whole series of image files and then joining them
> together using image processing software?
> Many thanks for your advice, Sarah.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160509/2f8328cf/attachment.html>
