[Qgis-user] Crayfish plugin OSError: libproj.so.0
Alexandre Neto
senhor.neto at gmail.com
Tue May 10 02:29:06 PDT 2016
I only have libproj9 package and libproj-dev.
Werner Macho <werner.macho at gmail.com> escreveu no dia terça, 10/05/2016 às
10:20:
> Hi,
> That error:
> OSError: libproj.so.0: cannot open shared object file: No such file or
> directory
> looks a bit suspicious to me .. Are you sure the package libproj0 is
> installed?
> regards
> Werner
> On Tue, May 10, 2016 at 11:16 AM, Alexandre Neto <senhor.neto at gmail.com>
> wrote:
> > I'm having troubles loading the Crayfish plugin in ubuntu 15.10 wily. No
> > problem whatsoever with windows tho.
> > Couldn't load plugin crayfish due to an error when calling its initGui()
> > method
> > directory
> > Traceback (most recent call last):
> > File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 335, in
> > startPlugin
> > plugins[packageName].initGui()
> > File "/home/alexandre/.qgis2/python/plugins/crayfish/plugin.py", line
> 73,
> > in initGui
> > if not ensure_library_installed():
> > File
> > "/home/alexandre/.qgis2/python/plugins/crayfish/gui/install_helper.py",
> line
> > 133, in ensure_library_installed
> > load_library()
> > File "/home/alexandre/.qgis2/python/plugins/crayfish/core.py", line
> 85, in
> > load_library
> > lib = ctypes.cdll.LoadLibrary(libpath)
> > File "/usr/lib/python2.7/ctypes/__init__.py", line 443, in LoadLibrary
> > return self._dlltype(name)
> > File "/usr/lib/python2.7/ctypes/__init__.py", line 365, in __init__
> > self._handle = _dlopen(self._name, mode)
> > directory
> > Python version: 2.7.10 (default, Oct 14 2015, 16:09:02) [GCC 5.2.1
> 20151010]
> > QGIS version: 2.15.0-Master Master, e9d3a3a
> > Python Path:
> > /usr/share/qgis/python
> > /usr/share/qgis/python/plugins
> > /usr/lib/python2.7
> > /usr/lib/python2.7/plat-x86_64-linux-gnu
> > /usr/lib/python2.7/lib-tk
> > /usr/lib/python2.7/lib-old
> > /usr/lib/python2.7/lib-dynload
> > /home/alexandre/.local/lib/python2.7/site-packages
> > /usr/local/lib/python2.7/dist-packages
> > /usr/lib/python2.7/dist-packages/PILcompat
> > /usr/lib/python2.7/dist-packages/gtk-2.0
> > /usr/lib/python2.7/dist-packages/ubuntu-sso-client
> > /home/alexandre/.qgis2//python
> > Alexandre Neto
> > @AlexNetoGeo
> > http://sigsemgrilhetas.wordpress.com
> > http://gisunchained.wordpress.com
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160510/9ab634c4/attachment.html>
