[Qgis-user] Crayfish plugin OSError: libproj.so.0
Werner Macho werner.macho at gmail.com
Tue May 10 02:20:09 PDT 2016
That error:
OSError: libproj.so.0: cannot open shared object file: No such file or directory
looks a bit suspicious to me .. Are you sure the package libproj0 is installed?
regards
Werner
On Tue, May 10, 2016 at 11:16 AM, Alexandre Neto <senhor.neto at gmail.com> wrote:
> I'm having troubles loading the Crayfish plugin in ubuntu 15.10 wily. No
> problem whatsoever with windows tho.
> Couldn't load plugin crayfish due to an error when calling its initGui()
> method
> directory
> Traceback (most recent call last):
>   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 335, in
> startPlugin
>     plugins[packageName].initGui()
>   File "/home/alexandre/.qgis2/python/plugins/crayfish/plugin.py", line 73,
> in initGui
>     if not ensure_library_installed():
>   File
> "/home/alexandre/.qgis2/python/plugins/crayfish/gui/install_helper.py", line
> 133, in ensure_library_installed
>     load_library()
>   File "/home/alexandre/.qgis2/python/plugins/crayfish/core.py", line 85, in
> load_library
>     lib = ctypes.cdll.LoadLibrary(libpath)
>   File "/usr/lib/python2.7/ctypes/__init__.py", line 443, in LoadLibrary
>     return self._dlltype(name)
>   File "/usr/lib/python2.7/ctypes/__init__.py", line 365, in __init__
>     self._handle = _dlopen(self._name, mode)
> directory
> Python version: 2.7.10 (default, Oct 14 2015, 16:09:02) [GCC 5.2.1 20151010]
> QGIS version: 2.15.0-Master Master, e9d3a3a
> Python Path:
> /usr/share/qgis/python
> /usr/share/qgis/python/plugins
> /usr/lib/python2.7
> /usr/lib/python2.7/plat-x86_64-linux-gnu
> /usr/lib/python2.7/lib-tk
> /usr/lib/python2.7/lib-old
> /usr/lib/python2.7/lib-dynload
> /home/alexandre/.local/lib/python2.7/site-packages
> /usr/local/lib/python2.7/dist-packages
> /usr/lib/python2.7/dist-packages/PILcompat
> /usr/lib/python2.7/dist-packages/gtk-2.0
> /usr/lib/python2.7/dist-packages/ubuntu-sso-client
> /home/alexandre/.qgis2//python
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
