[Qgis-user] Crayfish plugin OSError: libproj.so.0
Alexandre Neto senhor.neto at gmail.com
Tue May 10 02:16:09 PDT 2016
I'm having troubles loading the Crayfish plugin in ubuntu 15.10 wily. No
problem whatsoever with windows tho.
Couldn't load plugin crayfish due to an error when calling its initGui()
method
OSError: libproj.so.0: cannot open shared object file: No such file or
directory
  File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 335, in
startPlugin
    plugins[packageName].initGui()
  File "/home/alexandre/.qgis2/python/plugins/crayfish/plugin.py",
line 73, in initGui
    if not ensure_library_installed():
  File "/home/alexandre/.qgis2/python/plugins/crayfish/gui/install_helper.py",
line 133, in ensure_library_installed
    load_library()
  File "/home/alexandre/.qgis2/python/plugins/crayfish/core.py", line
85, in load_library
    lib = ctypes.cdll.LoadLibrary(libpath)
  File "/usr/lib/python2.7/ctypes/__init__.py", line 443, in LoadLibrary
    return self._dlltype(name)
  File "/usr/lib/python2.7/ctypes/__init__.py", line 365, in __init__
    self._handle = _dlopen(self._name, mode)
OSError: libproj.so.0: cannot open shared object file: No such file or directory
Python version: 2.7.10 (default, Oct 14 2015, 16:09:02) [GCC 5.2.1
20151010]
QGIS version: 2.15.0-Master Master, e9d3a3a
Python Path:
   - /usr/share/qgis/python
   - /home/alexandre/.qgis2/python
   - /home/alexandre/.qgis2/python/plugins
   - /usr/share/qgis/python/plugins
   - /usr/lib/python2.7
   - /usr/lib/python2.7/plat-x86_64-linux-gnu
   - /usr/lib/python2.7/lib-tk
   - /usr/lib/python2.7/lib-old
   - /usr/lib/python2.7/lib-dynload
   - /home/alexandre/.local/lib/python2.7/site-packages
   - /usr/local/lib/python2.7/dist-packages
   - /usr/lib/python2.7/dist-packages
   - /usr/lib/python2.7/dist-packages/PILcompat
   - /usr/lib/python2.7/dist-packages/gtk-2.0
   - /usr/lib/python2.7/dist-packages/ubuntu-sso-client
   - /home/alexandre/.qgis2//python
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160510/ad627f8e/attachment.html>
