[Qgis-user] Crayfish plugin OSError: libproj.so.0
Alexandre Neto senhor.neto at gmail.com
Tue May 10 03:02:50 PDT 2016
I'm using it straight from the plugins repository.
Creating the link worked but now it misses another library libhdf5.so.7
There is something fishy in my installation. Not sure if it's a crayfish
problem, neither a ubuntu 15.10 one. maybe I have some mixed dependencies
or something.
It works fine in Ubuntu 14.04 with QGIS 2.14
Thank you for your help.
Alexandre Neto
Werner Macho <werner.macho at gmail.com> escreveu no dia terça, 10/05/2016 às
10:35:
> hi!
> looks like something is searching for a not installed library. Did you
> compile crayfish yourself?
> Maybe a link called libproj.so.0 inside /usr/lib/x86_64-linux-gnu/ to
> libproj.so.9 does help?
> regards
> Werner
> On Tue, May 10, 2016 at 11:29 AM, Alexandre Neto <senhor.neto at gmail.com>
> wrote:
> > I only have libproj9 package and libproj-dev.
> às
> > 10:20:
> >> Hi,
> >> That error:
> >> OSError: libproj.so.0: cannot open shared object file: No such file or
> >> directory
> >> looks a bit suspicious to me .. Are you sure the package libproj0 is
> >> installed?
> >> regards
> >> Werner
> >> On Tue, May 10, 2016 at 11:16 AM, Alexandre Neto <senhor.neto at gmail.com
> >> wrote:
> >> > I'm having troubles loading the Crayfish plugin in ubuntu 15.10 wily.
> No
> >> > problem whatsoever with windows tho.
> >> > Couldn't load plugin crayfish due to an error when calling its
> initGui()
> >> > method
> >> > directory
> >> > Traceback (most recent call last):
> >> >   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 335, in
> >> > startPlugin
> >> >     plugins[packageName].initGui()
> >> >   File "/home/alexandre/.qgis2/python/plugins/crayfish/plugin.py",
> line
> >> > 73,
> >> > in initGui
> >> >     if not ensure_library_installed():
> >> >   File
> "/home/alexandre/.qgis2/python/plugins/crayfish/gui/install_helper.py",
> >> > line
> >> > 133, in ensure_library_installed
> >> >     load_library()
> >> >   File "/home/alexandre/.qgis2/python/plugins/crayfish/core.py", line
> >> > 85, in
> >> > load_library
> >> >     lib = ctypes.cdll.LoadLibrary(libpath)
> >> >   File "/usr/lib/python2.7/ctypes/__init__.py", line 443, in
> LoadLibrary
> >> >     return self._dlltype(name)
> >> >   File "/usr/lib/python2.7/ctypes/__init__.py", line 365, in __init__
> >> >     self._handle = _dlopen(self._name, mode)
> >> > directory
> >> > Python version: 2.7.10 (default, Oct 14 2015, 16:09:02) [GCC 5.2.1
> >> > 20151010]
> >> > QGIS version: 2.15.0-Master Master, e9d3a3a
> >> > Python Path:
> >> > /usr/share/qgis/python
> >> > /usr/share/qgis/python/plugins
> >> > /usr/lib/python2.7
> >> > /usr/lib/python2.7/plat-x86_64-linux-gnu
> >> > /usr/lib/python2.7/lib-tk
> >> > /usr/lib/python2.7/lib-old
> >> > /usr/lib/python2.7/lib-dynload
> >> > /home/alexandre/.local/lib/python2.7/site-packages
> >> > /usr/local/lib/python2.7/dist-packages
> >> > /usr/lib/python2.7/dist-packages/PILcompat
> >> > /usr/lib/python2.7/dist-packages/gtk-2.0
> >> > /usr/lib/python2.7/dist-packages/ubuntu-sso-client
> >> > /home/alexandre/.qgis2//python
> >> > Alexandre Neto
> >> > @AlexNetoGeo
> >> > http://sigsemgrilhetas.wordpress.com
> >> > http://gisunchained.wordpress.com
> >> > _______________________________________________
> >> > Qgis-user mailing list
> >> > Qgis-user at lists.osgeo.org
> >> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Alexandre Neto
> > @AlexNetoGeo
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160510/f9110df4/attachment.html>
