[Qgis-user] Crayfish plugin OSError: libproj.so.0
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Tue May 10 03:09:29 PDT 2016
I’d use qgis.org repo for all packages and dependencies.
Cheers,
Saber
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Alexandre Neto
Sent: 10 May 2016 11:03
To: Werner Macho; QGIS User
Subject: Re: [Qgis-user] Crayfish plugin OSError: libproj.so.0
I'm using it straight from the plugins repository.
Creating the link worked but now it misses another library libhdf5.so.7
There is something fishy in my installation. Not sure if it's a crayfish problem, neither a ubuntu 15.10 one. maybe I have some mixed dependencies or something.
It works fine in Ubuntu 14.04 with QGIS 2.14
Thank you for your help.
Alexandre Neto
Werner Macho <werner.macho at gmail.com> escreveu no dia terça, 10/05/2016 às 10:35:
hi!
looks like something is searching for a not installed library. Did you
compile crayfish yourself?
Maybe a link called libproj.so.0 inside /usr/lib/x86_64-linux-gnu/ to
libproj.so.9 does help?
regards
Werner
On Tue, May 10, 2016 at 11:29 AM, Alexandre Neto <senhor.neto at gmail.com> wrote:
> I only have libproj9 package and libproj-dev.
> 10:20:
>> Hi,
>> That error:
>> OSError: libproj.so.0: cannot open shared object file: No such file or
>> directory
>> looks a bit suspicious to me .. Are you sure the package libproj0 is
>> installed?
>> regards
>> Werner
>> On Tue, May 10, 2016 at 11:16 AM, Alexandre Neto <senhor.neto at gmail.com>
>> wrote:
>> > I'm having troubles loading the Crayfish plugin in ubuntu 15.10 wily. No
>> > problem whatsoever with windows tho.
>> > Couldn't load plugin crayfish due to an error when calling its initGui()
>> > method
>> > directory
>> > Traceback (most recent call last):
>> >   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 335, in
>> > startPlugin
>> >     plugins[packageName].initGui()
>> >   File "/home/alexandre/.qgis2/python/plugins/crayfish/plugin.py", line
>> > 73,
>> > in initGui
>> >     if not ensure_library_installed():
>> >   File
>> > "/home/alexandre/.qgis2/python/plugins/crayfish/gui/install_helper.py",
>> > line
>> > 133, in ensure_library_installed
>> >     load_library()
>> >   File "/home/alexandre/.qgis2/python/plugins/crayfish/core.py", line
>> > 85, in
>> > load_library
>> >     lib = ctypes.cdll.LoadLibrary(libpath)
>> >   File "/usr/lib/python2.7/ctypes/__init__.py", line 443, in LoadLibrary
>> >     return self._dlltype(name)
>> >   File "/usr/lib/python2.7/ctypes/__init__.py", line 365, in __init__
>> >     self._handle = _dlopen(self._name, mode)
>> > directory
>> > Python version: 2.7.10 (default, Oct 14 2015, 16:09:02) [GCC 5.2.1
>> > 20151010]
>> > QGIS version: 2.15.0-Master Master, e9d3a3a
>> > Python Path:
>> > /usr/share/qgis/python
>> > /usr/share/qgis/python/plugins
>> > /usr/lib/python2.7
>> > /usr/lib/python2.7/plat-x86_64-linux-gnu
>> > /usr/lib/python2.7/lib-tk
>> > /usr/lib/python2.7/lib-old
>> > /usr/lib/python2.7/lib-dynload
>> > /home/alexandre/.local/lib/python2.7/site-packages
>> > /usr/local/lib/python2.7/dist-packages
>> > /usr/lib/python2.7/dist-packages/PILcompat
>> > /usr/lib/python2.7/dist-packages/gtk-2.0
>> > /usr/lib/python2.7/dist-packages/ubuntu-sso-client
>> > /home/alexandre/.qgis2//python
>> > Alexandre Neto
>> > @AlexNetoGeo
>> > http://sigsemgrilhetas.wordpress.com
>> > http://gisunchained.wordpress.com
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto
> @AlexNetoGeo
Alexandre Neto
@AlexNetoGeo
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell pro
 ducts, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160510/251f567a/attachment.html>
