[Qgis-user] SQL display expression
Christoph Lauber christoph.lauber at geoplanteam.ch
Tue May 10 05:23:30 PDT 2016
Hi
I have a question about the display expression for forms.  The aim is to
show data of a table that is not related by QGIS.
What I would like to do is to write a SQL to my SpatiaLite database to fetch
some data. I suppose, that the display expression is restricted to the
“select column” clause like: “"pkuid"   ||  ' '  || CASE WHEN art = 1 THEN
'this' ELSE 'that' END”. When I put a select clause in it like “CASE WHEN
"art" THEN (SELECT value FROM WI_D_Inventar_Art WHERE id = "art") ELSE
'Undefined' END” I get an expression is invalid error (the expression works
in spatialite_gui). It seems that the SELECT keyword is not accepted.
Is there any possibility to write “free” SQL-Syntax for the display
expression?
I wrote already a function that connects to the database, fetchs the data
and closes the database. It works, but it is slow.
Thanks for your help.
Freundliche Grüsse
Christoph Lauber
GeoplanTeam AG dipl. Ing. ETH/SIA Hutzli+Kluser
Vermessung | Geoinformatik | Umwelttechnik
Egliweg 6, CH - 2560 Nidau
Phone:(+41) - 032 332 78 00
Fax:(+41) - 032 332 78 01
Web:  <http://www.geoplanteam.ch/> www.geoplanteam.ch
E-Mail:  <mailto:christoph.lauber at geoplanteam.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160510/292c6f34/attachment.html>
