[Qgis-user] Crayfish plugin OSError: libproj.so.0
Alexandre Neto
senhor.neto at gmail.com
Wed May 11 00:00:54 PDT 2016
Thank you, I will check it out.
A qua, 11/05/2016, 04:05, Martin Dobias <wonder.sk at gmail.com> escreveu:
> Hi Alexandre
> On Tue, May 10, 2016 at 6:02 PM, Alexandre Neto <senhor.neto at gmail.com>
> wrote:
> > I'm using it straight from the plugins repository.
> > Creating the link worked but now it misses another library libhdf5.so.7
> > There is something fishy in my installation. Not sure if it's a crayfish
> > problem, neither a ubuntu 15.10 one. maybe I have some mixed
> dependencies or
> > something.
> > It works fine in Ubuntu 14.04 with QGIS 2.14
> The precompiled Crayfish binaries are done on Ubuntu 14.04 and with
> the package changes in Ubuntu >= 15.10 the binaries do not work there.
> I have filed a bug report to fix the problem:
> https://github.com/lutraconsulting/qgis-crayfish-plugin/issues/187
> In the meanwhile you should be able to compile the support library
> yourself, see the instructions:
> https://github.com/lutraconsulting/qgis-crayfish-plugin/blob/master/README.md
> Cheers
> Martin
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160511/8342ca02/attachment.html>
