[Qgis-user] QGIS Atlas Help
Richard McDonnell richard.mcdonnell at opw.ie
Wed May 11 06:06:00 PDT 2016
Saber,
I may have inadvertently misled you on point 2, I mentioned /*Labels*/,
I should have said /*Annotations*/.
I am using HTML annotations to label some points.
I had tried your suggestion, but unfortunately, it does not fix the
issue, Its odd, because in the Map screen if I switch off the Layer, the
labels disappear also, but it doesn't happen in the Key Plan.
On 11/05/2016 12:57, Saber Razmjooei wrote:
> For 2. You need to use presets. Preset is linked with layers’ multiple
> style. So, in each preset, you can have a specific style for the layer.
> See Presets section of this tutorial:
> http://www.lutraconsulting.co.uk/blog/2015/11/15/print-composer-presets/
> For 3, can’t you add an expression like:
> [% $atlasfeature %]
> Cheers,
> Saber
> *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Richard McDonnell
> *Sent:* 11 May 2016 12:48
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] QGIS Atlas Help
> Hello all!!
> I am in need of your collective expertise, few things.
>  1. How can I word wrap Column Headers on a Attribute table within
>     Composer, there is an option to word wrap, but it does not seem to
>     work, I have tried *\n* also with no luck.
>  2. I also have a Main Map with Key Plan, I have some labels I want to
>     see in the main Map, but they also appear in Key Plan (Don't want
>     this)
>  3. I also have Sheet Numbering, I wish to automate, I would like
>     something like "Sheet 1 of 30" I have seen ways online, but I am
>     looking to pull the Atlas Features */atlas_featurenumber /*and
>     */atlas_totalfeatures/*, I cant find any help on these??
> Any Help appreciated!!!
> *_Richard McDonnell_*
> *GIS Specialist PgD GIS AssocSCSI*
> *OPW FRM Data Management*
> *52 Stephens Green, Dublin 2.*
> TEL: 01 6476543
> OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
> OPW - Looking to the future - Caring for the past
> <http://www.opw.ie/>
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed. If you have received this email in error please notify
> the system manager. This message contains confidential information and
> is intended only for the individual named. If you are not the named
> addressee you should not disseminate, distribute or copy this e-mail.
> Please notify the sender immediately by e-mail if you have received
> this e-mail by mistake and delete this e-mail from your system. If you
> are not the intended recipient you are notified that disclosing,
> copying, distributing or taking any action in reliance on the contents
> of this information is strictly prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no
> responsibility for vir! uses is taken and it is your responsibility to
> carry out such checks as you feel appropriate.
> If this email contains a quote or offer to sell products, carry out
> work or perform services then our standard terms and conditions
> <http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf>
> shall apply unless explicitly stated otherwise.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
TEL: 01 6476543
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160511/fff9325c/attachment.html>
