[Qgis-user] QGIS Atlas Help
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Wed May 11 06:14:51 PDT 2016
Richard,
Not sure, how to handle Annotations on/off state in a multi frame map composer page. It is not for sure supported by preset.
Cheers,
Saber
From: Richard McDonnell [mailto:richard.mcdonnell at opw.ie]
Sent: 11 May 2016 14:06
To: Saber Razmjooei; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS Atlas Help
Saber,
I may have inadvertently misled you on point 2, I mentioned Labels, I should have said Annotations.
I am using HTML annotations to label some points.
I had tried your suggestion, but unfortunately, it does not fix the issue, Its odd, because in the Map screen if I switch off the Layer, the labels disappear also, but it doesn't happen in the Key Plan.
On 11/05/2016 12:57, Saber Razmjooei wrote:
For 2. You need to use presets. Preset is linked with layers’ multiple style. So, in each preset, you can have a specific style for the layer.
See Presets section of this tutorial:
http://www.lutraconsulting.co.uk/blog/2015/11/15/print-composer-presets/
For 3, can’t you add an expression like:
[% $atlasfeature %]
Cheers,
Saber
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Richard McDonnell
Sent: 11 May 2016 12:48
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] QGIS Atlas Help
Hello all!!
I am in need of your collective expertise, few things.
1. How can I word wrap Column Headers on a Attribute table within Composer, there is an option to word wrap, but it does not seem to work, I have tried \n also with no luck.
2. I also have a Main Map with Key Plan, I have some labels I want to see in the main Map, but they also appear in Key Plan (Don't want this)
3. I also have Sheet Numbering, I wish to automate, I would like something like "Sheet 1 of 30" I have seen ways online, but I am looking to pull the Atlas Features atlas_featurenumber and atlas_totalfeatures, I cant find any help on these??
Any Help appreciated!!!
Richard McDonnell
GIS Specialist PgD GIS AssocSCSI
OPW FRM Data Management
52 Stephens Green, Dublin 2.
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
<http://www.opw.ie/>
Email Disclaimer: http://www.opw.ie/en/disclaimer/
_____
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for vir! uses is taken and it is your responsibility to carry out such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions <http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf> shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Richard McDonnell
TEL: 01 6476543
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160511/e9eb9de9/attachment.html>
