[Qgis-user] Plugin required
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Thu May 12 09:06:08 PDT 2016
I believe FiberPlanIT is a plugin you get when you pay for the FiberPlanIT software.  I does not seem to be available otherwise:(
Nicolas
On May 12, 2016 11:31 AM, "Sheikh Salman Ahmad [via OSGeo.org]	" <ml-node+s1560n5266060h21 at n6.nabble.com> wrote:
I need plugin of FiberPlanIT for QGIS, if anyone have it then kindly share. I'll be very grateful > To: qgis-user@lists.osgeo.org > From: r.nijssen@terglobo.nl > Date: Thu, 12 May 2016 15:56:28 +0200 > Subject: Re: [Qgis-user] Export plugins list > > Never tried, but i expect that you can just copy the contents of your > old "plugins" directory to your new. In my case this is: > > ~/.qgis2/python/plugins/ > > Raymond > > > > On 14-04-16 11:21, Joris Hintjens wrote: > > No answer anyone? > > I had the same issue some months ago. Did it manually. (print screen of plugin list to transmit the info) > > > > greets > > joris > > > >> Op 11 apr. 2016, om 10:33 heeft ah franz <ahfranz73@gmail.com> het volgende geschreven: > >> > >> it's possible make a command to export the list (xml) of installed plugins ?i.e. for transfer in other pc . > >> > >> Thank's Franz > >> _______________________________________________ > >> Qgis-user mailing list > >> Qgis-user@lists.osgeo.org > >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user > >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user > > > > _______________________________________________ > > Qgis-user mailing list > > Qgis-user@lists.osgeo.org > > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user > > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user > > > _______________________________________________ > Qgis-user mailing list > Qgis-user@lists.osgeo.org > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Export-plugins-list-tp5260605p5266060.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Export-plugins-list-tp5260605p5266067.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160512/c53061d7/attachment.html>
