[Qgis-user] Plugin required
Sheikh Salman Ahmad salman__ at msn.com
Fri May 13 23:05:54 PDT 2016
Hi
Can you confirm me the price.
Date: Thu, 12 May 2016 09:06:08 -0700
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Plugin required
I believe FiberPlanIT is a plugin you get when you pay for the FiberPlanIT software.  I does not seem to be available otherwise:(
Nicolas
On May 12, 2016 11:31 AM, "Sheikh Salman Ahmad [via OSGeo.org]	" <[hidden email]> wrote:
I need plugin of FiberPlanIT for QGIS, if anyone have it then kindly share. I'll be very grateful
> From: r.nijssen at terglobo.nl
> Date: Thu, 12 May 2016 15:56:28 +0200
> Subject: Re: [Qgis-user] Export plugins list
> Never tried, but i expect that you can just copy the contents of your
> old "plugins" directory to your new. In my case this is:
> ~/.qgis2/python/plugins/
> Raymond
> On 14-04-16 11:21, Joris Hintjens wrote:
> > No answer anyone?
> > I had the same issue some months ago. Did it manually. (print screen of plugin list to transmit the info)
> > greets
> > joris
> >> Op 11 apr. 2016, om 10:33 heeft ah franz <ahfranz73 at gmail.com> het volgende geschreven:
> >> it's possible make a command to export the list (xml) of installed plugins ?i.e. for transfer in other pc .
> >> Thank's Franz
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
<a href="/user/SendEmail.jtp?type=node&node=5266060&i=0">[hidden email]
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Export-plugins-list-tp5260605p5266060.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
		To unsubscribe from Quantum GIS - User, <a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click here.
		<a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml" style="font:9px serif">NAML
View this message in context: Re: Plugin required
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160514/f33d0111/attachment.html>
