[Qgis-user] Plugin required
Sheikh Salman Ahmad salman__ at msn.com
Thu May 12 09:25:56 PDT 2016
I need plugin of FiberPlanIT for QGIS, if anyone have it then kindly share. I'll be very grateful
> To: qgis-user at lists.osgeo.org
> From: r.nijssen at terglobo.nl
> Date: Thu, 12 May 2016 15:56:28 +0200
> Subject: Re: [Qgis-user] Export plugins list
> Never tried, but i expect that you can just copy the contents of your
> old "plugins" directory to your new. In my case this is:
> ~/.qgis2/python/plugins/
> Raymond
> On 14-04-16 11:21, Joris Hintjens wrote:
> > No answer anyone?
> > I had the same issue some months ago. Did it manually. (print screen of plugin list to transmit the info)
> > greets
> > joris
> >> Op 11 apr. 2016, om 10:33 heeft ah franz <ahfranz73 at gmail.com> het volgende geschreven:
> >> it's possible make a command to export the list (xml) of installed plugins ?i.e. for transfer in other pc .
> >> Thank's Franz
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160512/046a2dca/attachment.html>
