[Qgis-user] Export plugins list
ah franz
ahfranz73 at gmail.com
Fri May 27 05:50:59 PDT 2016
Hi everyone, I tried to copy/paste plugins folder from win10 to win10
and fedora to fedora, but I got a negative result.
Now I'm working on a small Python script to export the xml file with
the list of plugins installed
and always through import scripts into another pc, which later will be
updated plugins via the official repositories.
I hope to work correctly,will keep you updated.
Greetings Franz
On Thu, May 12, 2016 at 3:56 PM, Raymond Nijssen <r.nijssen at terglobo.nl>
wrote:
> Never tried, but i expect that you can just copy the contents of your
> old "plugins" directory to your new. In my case this is:
> ~/.qgis2/python/plugins/
> Raymond
> On 14-04-16 11:21, Joris Hintjens wrote:
> > No answer anyone?
> > I had the same issue some months ago. Did it manually. (print screen of
> plugin list to transmit the info)
> > greets
> > joris
> >> Op 11 apr. 2016, om 10:33 heeft ah franz <ahfranz73 at gmail.com> het
> volgende geschreven:
> >> it's possible make a command to export the list (xml) of installed
> plugins ?i.e. for transfer in other pc .
> >> Thank's Franz
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160527/9401a0e5/attachment.html>
