[Qgis-user] Export plugins list
Nathan Woodrow
madmanwoo at gmail.com
Fri May 27 05:52:17 PDT 2016
What happened when you copied the plugins?
I have done this many times without any issues.
On Fri, May 27, 2016 at 10:50 PM, ah franz <ahfranz73 at gmail.com> wrote:
> Hi everyone, I tried to copy/paste plugins folder from win10 to win10 and fedora to fedora, but I got a negative result.
> Now I'm working on a small Python script to export the xml file with the list of plugins installed
> and always through import scripts into another pc, which later will be updated plugins via the official repositories.
> I hope to work correctly,will keep you updated.
> Greetings Franz
> On Thu, May 12, 2016 at 3:56 PM, Raymond Nijssen <r.nijssen at terglobo.nl>
> wrote:
>> Never tried, but i expect that you can just copy the contents of your
>> old "plugins" directory to your new. In my case this is:
>> ~/.qgis2/python/plugins/
>> Raymond
>> On 14-04-16 11:21, Joris Hintjens wrote:
>> > No answer anyone?
>> > I had the same issue some months ago. Did it manually. (print screen of
>> plugin list to transmit the info)
>> > greets
>> > joris
>> >> Op 11 apr. 2016, om 10:33 heeft ah franz <ahfranz73 at gmail.com> het
>> volgende geschreven:
>> >> it's possible make a command to export the list (xml) of installed
>> plugins ?i.e. for transfer in other pc .
>> >> Thank's Franz
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> >> Qgis-user at lists.osgeo.org
>> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160527/67da75c3/attachment.html>
