[Qgis-user] Export plugins list
ah franz ahfranz73 at gmail.com
Fri May 27 05:56:55 PDT 2016
I found only the previous plugins, obviously not working.
On Fri, May 27, 2016 at 2:52 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> What happened when you copied the plugins?
> I have done this many times without any issues.
> On Fri, May 27, 2016 at 10:50 PM, ah franz <ahfranz73 at gmail.com> wrote:
>> Hi everyone, I tried to copy/paste plugins folder from win10 to win10 and fedora to fedora, but I got a negative result.
>> Now I'm working on a small Python script to export the xml file with the list of plugins installed
>> and always through import scripts into another pc, which later will be updated plugins via the official repositories.
>> I hope to work correctly,will keep you updated.
>> Greetings Franz
>> On Thu, May 12, 2016 at 3:56 PM, Raymond Nijssen <r.nijssen at terglobo.nl>
>> wrote:
>>> Never tried, but i expect that you can just copy the contents of your
>>> old "plugins" directory to your new. In my case this is:
>>> ~/.qgis2/python/plugins/
>>> Raymond
>>> On 14-04-16 11:21, Joris Hintjens wrote:
>>> > No answer anyone?
>>> > I had the same issue some months ago. Did it manually. (print screen
>>> of plugin list to transmit the info)
>>> > greets
>>> > joris
>>> >> Op 11 apr. 2016, om 10:33 heeft ah franz <ahfranz73 at gmail.com> het
>>> volgende geschreven:
>>> >> it's possible make a command to export the list (xml) of installed
>>> plugins ?i.e. for transfer in other pc .
>>> >> Thank's Franz
>>> >> _______________________________________________
>>> >> Qgis-user mailing list
>>> >> Qgis-user at lists.osgeo.org
>>> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160527/d2c25e63/attachment.html>
