[Qgis-user] problem with QGIS installation
Filipe Dias
filipesdias at gmail.com
Fri May 13 15:03:56 PDT 2016
Thanks Randal. Unfortunately now I have a different problem...Any ideas?
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
python-qgis : Depends: python-qgis-common (= 1:2.14.2+20trusty) but it is
not going to be installed
Depends: python-qscintilla2 but it is not installable
Depends: python-pyspatialite but it is not installable
Depends: libqgispython2.14.2 but it is not going to be
installed
Depends: libqgis-analysis2.14.2 but it is not going to be
installed
Depends: libqgis-core2.14.2 but it is not going to be
installed
Depends: libqgis-gui2.14.2 but it is not going to be
installed
Depends: libqgis-networkanalysis2.14.2 but it is not going
to be installed
Depends: libqgis-server2.14.2 but it is not going to be
installed
Recommends: liblwgeom-dev but it is not installable
qgis : Depends: libgdal1h (>= 1.8.0) but it is not installable
Depends: libgeos-c1 (>= 3.4.2) but it is not installable
Depends: libqgis-analysis2.14.2 but it is not going to be installed
Depends: libqgis-app2.14.2 but it is not going to be installed
Depends: libqgis-core2.14.2 but it is not going to be installed
Depends: libqgis-gui2.14.2 but it is not going to be installed
Depends: libqgis-networkanalysis2.14.2 but it is not going to be
installed
Depends: qgis-providers (= 1:2.14.2+20trusty) but it is not going
to be installed
Depends: qgis-common (= 1:2.14.2+20trusty) but it is not going to
be installed
Recommends: qgis-plugin-grass but it is not going to be installed
Recommends: qgis-provider-grass but it is not going to be installed
Recommends: qgis-plugin-globe but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
On Fri, May 13, 2016 at 9:16 PM, Randal Hale <
rjhale at northrivergeographic.com> wrote:
> UbuntuGIS is in the middle of being revived. For right now I'd go with
> this:
> deb http://qgis.org/debian trusty main
> deb-src http://qgis.org/debian trusty main
> Remove your current installation/repos and install it from the above.
> You will most likely need to do the following also:
> wget -O - http://qgis.org/downloads/qgis-2015.gpg.key | gpg --import
> gpg --fingerprint 3FF5FFCAD71472C4
> Join the UbuntuGIS Email list it should be updated shortly.
> http://lists.osgeo.org/mailman/listinfo/ubuntu
> Randy
> On 05/13/2016 03:52 PM, Filipe Dias wrote:
> Hi
> I'm installing QGIS on a clean Ubuntu 14.04 installation but I'm getting
> this error. I have these two repositories installed. Any idea about what's
> happening?
> Thanks
> Cheers
> deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu trusty
> main
> deb http://qgis.org/ubuntugis trusty main
> fd at fd-Lenovo:~$ sudo apt-get install qgis python-qgis
> libcogl15 : Depends: libegl1-mesa-drivers
> E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused
> by held packages.
> Qgis-user mailing listQgis-user at lists.osgeo.org
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Randal Hale
> North River Geographic Systems, Inchttp://www.northrivergeographic.com423.653.3611 rjhale at northrivergeographic.com
> twitter:rjhale http://about.me/rjhalehttp://www.northrivergeographic.com/introduction-to-quantum-gishttps://www.facebook.com/NRGSInc
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160513/ebae9421/attachment.html>
