[Qgis-user] features that represent TWO attributes
DelazJ delazj at gmail.com
Sat May 14 00:51:41 PDT 2016
You're welcome, dude...
The best thing is to reply to the list so that everybody is aware of
how/whether your issue has been solved or the workaround found or to have
other inputs that community can benefit from.
Sorry for the multiple times my reply was sent. This is due to a wrong
config on my cell phone that returns a fail on sending although the message
was really sent. Thus it retries to send again, and again (and it goes
every time until I stop it manually, what I did with a little delay
yesterday.... really noisy).
My apologies again
2016-05-13 20:51 GMT+02:00 Stephen Sacks <sacks44 at earthlink.net>:
>         YES !!  It works !  Thank you so much.   I appreciate your clear
> advice.
>                      Steve
> P.S.  I'm not sure how this user list works.  Should I send replies
> directly to you or to the list ?  I got your latest message three times.
> On 5/13/2016 12:12 PM, Junior wrote:
> Hi Steve,
> Let's take the single symbol renderer
> <http://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#single-symbol-renderer>
> (also linked in the previous text I sent), the data-defined override button
> is the figure available after "width" spinbox in the screenshot. And this
> set of options in the right is the so called "upper level", when the
> upper symbol in the left panel is being selected. The place where you find
> the size assistant. If I'm not wrong, for point features, the option to use
> is called "size" not "width".
> Note that in your case, you want to do a multivariate analysis....
> To go further:
> Given that there are some generic structure in the way Qgis handles
> features styling, the doc is organized in a way to be less redundant (for
> readers and translators), so for a beginner you may need to follow the
> links mentioned in the text to build the whole picture (don't worry, no
> need to read all the doc :) ), namely:
> - the two already shown
> http://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/style_library.html#the-symbol-selector
> Ask if you need more precision...
> Envoyé depuis mon HTC
> ----- Reply message -----
> De : "Stephen Sacks" <sacks44 at earthlink.net> <sacks44 at earthlink.net>
> Pour : "DelazJ" <delazj at gmail.com> <delazj at gmail.com>
> Objet : [Qgis-user] features that represent TWO attributes
> Date : ven., mai 13, 2016 16:24
> Hi Harrissou -
>    Thank you for taking time to provide to me the link below.  It seems to
> be exactly what I need.  Unfortunately, I'm stuck at the very beginning,
> where the instructions say to click the "Data-defined override button" at
> the "upper level of the symbol tree."   Since I'm very new to QGIS, I don't
> know how to find the "upper level of the symbol tree" and hence I can't
> locate the "Data-defined override button."  Please provide me with more
> guidance.
>             Thanks.
>                     Steve
> On 5/13/2016 12:14 AM, DelazJ wrote:
> Hi,
> Steve, can you give a look to
> http://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#proportional-symbol-and-multivariate-analysis
> HTH,
> Harrissou
> 2016-05-13 1:27 GMT+02:00 Stephen Sacks <sacks44 at earthlink.net>:
>> I'm trying to create a layer with features that reflect two attributes.
>> I want each point to be marked by a circle whose (1) color reflects its
>> type (city, town, or suburb), and whose (2) size reflects its population.
>>   From layer properties, I first select Style and choose "Categorized"
>> based on column "Type."  This gives me circles with different colors for
>> different types.  Then I choose "Graduated" based on column "Population."
>> This gives me circles with different sizes.  Unfortunately, setting the
>> sizes wipes out the different colors.  I've tried setting the sizes first,
>> but then setting the colors wipes out the different sizes.  How do I set
>> both size and color ?
>>    I'm using QGIS 2.14.1 on Windows 7.
>>    Thanks in advance for your help.
>> Steve
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160514/80b5cc82/attachment.html>
