[Qgis-user] Print composer fails on print or export
Carlo Cormio carlo.cormio at gmail.com
Thu May 26 00:29:13 PDT 2016
Thank you Alexandre, it works without Bing map. Is it due to a bug o to
some copyright restrictions?
Bye,
Carlo
Il 26/05/2016 08:09, Alexandre Neto ha scritto:
> Please try removing bing maps. Also, try exporting the PDF directly.
> A qua, 25/05/2016, 20:46, CARLO CORMIO <carlo.cormio at gmail.com
> <mailto:carlo.cormio at gmail.com>> escreveu:
>     Dear All,
>     I'm trying to print a couple of maps (with rasters, vectors and
>     bing maps) in a canvas through QGIS map composer. Setting the
>     composition (adding map, text, scale, etc) works fine, as always,
>     but when I try to print or export it in any file format the canvas
>     disappear, no error message pops up, no hardware runs (no lights
>     blinking on my PC).
>     Page setup is custom (170 x 100 mm) and the maps reach page
>     border, I don't know if this could be a problem.
>     I had the same problem with different QGIS versione (2.12 and
>     2.14), so maybe it is a local problem. Any idea? I'm working on
>     Windows 10 64 bit, and use PDFCreator as pdf printer.
>     Thanks in advance,
>     Carlo
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160526/52d527ae/attachment.html>
