[Qgis-user] Print composer fails on print or export
Alexandre Neto senhor.neto at gmail.com
Thu May 26 01:08:55 PDT 2016
Use quickwebservices plugin instead of openlayers plugin. It works better.
You may have luck with it.
A qui, 26/05/2016, 08:29, Carlo Cormio <carlo.cormio at gmail.com> escreveu:
> Thank you Alexandre, it works without Bing map. Is it due to a bug o to
> some copyright restrictions?
> Bye,
> Carlo
> Il 26/05/2016 08:09, Alexandre Neto ha scritto:
> Please try removing bing maps. Also, try exporting the PDF directly.
> A qua, 25/05/2016, 20:46, CARLO CORMIO <carlo.cormio at gmail.com> escreveu:
>> Dear All,
>> I'm trying to print a couple of maps (with rasters, vectors and bing
>> maps) in a canvas through QGIS map composer. Setting the composition
>> (adding map, text, scale, etc) works fine, as always, but when I try to
>> print or export it in any file format the canvas disappear, no error
>> message pops up, no hardware runs (no lights blinking on my PC).
>> Page setup is custom (170 x 100 mm) and the maps reach page border, I
>> don't know if this could be a problem.
>> I had the same problem with different QGIS versione (2.12 and 2.14), so
>> maybe it is a local problem. Any idea? I'm working on Windows 10 64 bit,
>> and use PDFCreator as pdf printer.
>> Thanks in advance,
>> Carlo
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160526/5a5800be/attachment.html>
