[Qgis-user] Print composer fails on print or export
Carlo Cormio
carlo.cormio at gmail.com
Thu May 26 02:16:15 PDT 2016
Thanks again Alexandre, but there's a problem with Quickmapservices
plugin (Error message: No module named requests), on QGIS 2.14.3.
Il 26/05/2016 10:08, Alexandre Neto ha scritto:
> Use quickwebservices plugin instead of openlayers plugin. It works
> better. You may have luck with it.
> A qui, 26/05/2016, 08:29, Carlo Cormio <carlo.cormio at gmail.com
> <mailto:carlo.cormio at gmail.com>> escreveu:
> Thank you Alexandre, it works without Bing map. Is it due to a bug
> o to some copyright restrictions?
> Bye,
> Carlo
> Il 26/05/2016 08:09, Alexandre Neto ha scritto:
>> Please try removing bing maps. Also, try exporting the PDF directly.
>> A qua, 25/05/2016, 20:46, CARLO CORMIO <carlo.cormio at gmail.com
>> Dear All,
>> I'm trying to print a couple of maps (with rasters, vectors
>> and bing maps) in a canvas through QGIS map composer. Setting
>> the composition (adding map, text, scale, etc) works fine, as
>> always, but when I try to print or export it in any file
>> format the canvas disappear, no error message pops up, no
>> hardware runs (no lights blinking on my PC).
>> Page setup is custom (170 x 100 mm) and the maps reach page
>> border, I don't know if this could be a problem.
>> I had the same problem with different QGIS versione (2.12 and
>> 2.14), so maybe it is a local problem. Any idea? I'm working
>> on Windows 10 64 bit, and use PDFCreator as pdf printer.
>> Thanks in advance,
>> Carlo
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Alexandre Neto
>> @AlexNetoGeo
>> http://sigsemgrilhetas.wordpress.com
>> http://gisunchained.wordpress.com
> Alexandre Neto
> @AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160526/5a60d390/attachment.html>
