[Qgis-user] Print composer fails on print or export [Solved]
Carlo Cormio carlo.cormio at gmail.com
Sun May 29 14:25:20 PDT 2016
Dear all,
sorry for the delay. Just to update everybody, as suggested by Alexandre
I'm now using Quickmapservices (fixed very quickly by nextgis, thank
you!!!) and prints are perfect again.
Bye,
Carlo
Il 26/05/2016 11:16, Carlo Cormio ha scritto:
> Thanks again Alexandre, but there's a problem with Quickmapservices
> plugin (Error message: No module named requests), on QGIS 2.14.3.
> Il 26/05/2016 10:08, Alexandre Neto ha scritto:
>> Use quickwebservices plugin instead of openlayers plugin. It works
>> better. You may have luck with it.
>> A qui, 26/05/2016, 08:29, Carlo Cormio <carlo.cormio at gmail.com> escreveu:
>>     Thank you Alexandre, it works without Bing map. Is it due to a
>>     bug o to some copyright restrictions?
>>     Bye,
>>     Carlo
>>     Il 26/05/2016 08:09, Alexandre Neto ha scritto:
>>>     Please try removing bing maps. Also, try exporting the PDF directly.
>>>     A qua, 25/05/2016, 20:46, CARLO CORMIO <carlo.cormio at gmail.com
>>>     <mailto:carlo.cormio at gmail.com>> escreveu:
>>>         Dear All,
>>>         I'm trying to print a couple of maps (with rasters, vectors
>>>         and bing maps) in a canvas through QGIS map composer.
>>>         Setting the composition (adding map, text, scale, etc) works
>>>         fine, as always, but when I try to print or export it in any
>>>         file format the canvas disappear, no error message pops up,
>>>         no hardware runs (no lights blinking on my PC).
>>>         Page setup is custom (170 x 100 mm) and the maps reach page
>>>         border, I don't know if this could be a problem.
>>>         I had the same problem with different QGIS versione (2.12
>>>         and 2.14), so maybe it is a local problem. Any idea? I'm
>>>         working on Windows 10 64 bit, and use PDFCreator as pdf printer.
>>>         Thanks in advance,
>>>         Carlo
>>>         _______________________________________________
>>>         Qgis-user mailing list
>>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>         List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>         Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>     Alexandre Neto
>>>     @AlexNetoGeo
>>>     http://sigsemgrilhetas.wordpress.com
>>>     http://gisunchained.wordpress.com
>> Alexandre Neto
>> @AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160529/fa6eab9f/attachment.html>
