[Qgis-user] SQL display expression
Christoph Lauber
christoph.lauber at geoplanteam.ch
Thu May 26 05:05:15 PDT 2016
Hi Andreas
Even my answer comes late…
Thanks for your reply and propositions.
I tried all 3 possibilities and the attribute(getFeature(…)) solution works perfectly for my needs.
With “not related” I meant, that the main table and the domain table (list lookup) only have a relation by an intermediate table. I think you understood right :)
Freundliche Grüsse
Christoph Lauber
Von: Neumann, Andreas [mailto:a.neumann at carto.net]
Gesendet: Dienstag, 10. Mai 2016 15:31
An: Christoph Lauber <christoph.lauber at geoplanteam.ch>
Cc: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] SQL display expression
Hi Christoph,
Are you talking about the left column in the forms view?
What do you mean by "not related"? Do you mean related, but not contained in the same table?
Is this for a value list lookup?
For a 1:1 relation?
QGIS expressions don't know "SELECT". The expression always works on a single feature. It can't return records.
There could be several ways to do what you want:
1. use joins (layer properties --> joins)
2. use the attribute(getFeature(....)) expression
3. Create a virtual layer (starting from version 2.14) --> see https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/virtual_layers.html
I hope that one of the above ways help you solve your problem.
Greetings,
Andreas
On 2016-05-10 14:23, Christoph Lauber wrote:
Hi
I have a question about the display expression for forms. The aim is to show data of a table that is not related by QGIS.
What I would like to do is to write a SQL to my SpatiaLite database to fetch some data. I suppose, that the display expression is restricted to the “select column” clause like: “"pkuid" || ' ' || CASE WHEN art = 1 THEN 'this' ELSE 'that' END”. When I put a select clause in it like “CASE WHEN "art" THEN (SELECT value FROM WI_D_Inventar_Art WHERE id = "art") ELSE 'Undefined' END” I get an expression is invalid error (the expression works in spatialite_gui). It seems that the SELECT keyword is not accepted.
Is there any possibility to write “free” SQL-Syntax for the display expression?
I wrote already a function that connects to the database, fetchs the data and closes the database. It works, but it is slow.
Thanks for your help.
Freundliche Grüsse
Christoph Lauber
GeoplanTeam AG dipl. Ing. ETH/SIA Hutzli+Kluser
Vermessung | Geoinformatik | Umwelttechnik
Egliweg 6, CH - 2560 Nidau
Phone:(+41) - 032 332 78 00
Fax:(+41) - 032 332 78 01
Web: <http://www.geoplanteam.ch/> www.geoplanteam.ch
E-Mail: <mailto:christoph.lauber at geoplanteam.ch> christoph.lauber at geoplanteam.ch
Qgis-user mailing list
Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160526/d02f7237/attachment.html>
