[Qgis-user] Fwd: Default line width in styles
Carlos Cerdán sig.upagu at gmail.com
Mon May 30 09:25:14 PDT 2016
Thank you very much Tyler, that's that I wanted, but it works for the
current project only (QGIS 2.14.3 - Ubuntu).
I would like to set the default width of polygon border lines to all of new
projects in one step.
Perhaps it can be done from a text-configuration file?
2016-05-30 10:44 GMT-05:00 Tyler Veinot <tylerkveinot at gmail.com>:
> Under Project goto--> Project Properties goto--> Default Styles There you
> can change the defaults for new layer symbology including line width.
>    - The *Default Styles* menu lets you control how new layers will be
>    drawn when they do not have an existing .qml style defined. You can
>    also set the default transparency level for new layers and whether symbols
>    should have random colours assigned to them. There is also an additional
>    section where you can define specific colors for the running project. You
>    can find the added colors in the drop down menu of the color dialog window
>    present in each renderer."
> Good question though, I did not know how to do this until I looked it up.
> Tyler
> On Mon, May 30, 2016 at 11:49 AM, Carlos Cerdán <sig.upagu at gmail.com>
> wrote:
>> Hi list:
>> How can i change the default line width in styles?
>> Sorry if it's a trivial question, but I can't find it. I prefer to work
>> with 1.5 mm but default is 2.6
>> Carlos
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160530/e3076ecd/attachment.html>
