[Qgis-user] Fwd: Default line width in styles
Goyo
goyodiaz at gmail.com
Tue May 31 09:41:54 PDT 2016
2016-05-30 18:25 GMT+02:00 Carlos Cerdán <sig.upagu at gmail.com>:
> Thank you very much Tyler, that's that I wanted, but it works for the
> current project only (QGIS 2.14.3 - Ubuntu).
> I would like to set the default width of polygon border lines to all of new
> projects in one step.
> Perhaps it can be done from a text-configuration file?
I did not try but I guess you can create an empty project with your
preferred defaults and use it as the default project template.
Goyo
> 2016-05-30 10:44 GMT-05:00 Tyler Veinot <tylerkveinot at gmail.com>:
>> Under Project goto--> Project Properties goto--> Default Styles There you
>> can change the defaults for new layer symbology including line width.
>> The Default Styles menu lets you control how new layers will be drawn when
>> they do not have an existing .qml style defined. You can also set the
>> default transparency level for new layers and whether symbols should have
>> random colours assigned to them. There is also an additional section where
>> you can define specific colors for the running project. You can find the
>> added colors in the drop down menu of the color dialog window present in
>> each renderer."
>> Good question though, I did not know how to do this until I looked it up.
>> Tyler
>> On Mon, May 30, 2016 at 11:49 AM, Carlos Cerdán <sig.upagu at gmail.com>
>> wrote:
>>> Hi list:
>>> How can i change the default line width in styles?
>>> Sorry if it's a trivial question, but I can't find it. I prefer to work
>>> with 1.5 mm but default is 2.6
>>> Carlos
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
