[Qgis-user] [QGIS-UX] Processing UI: moving "open layer" checkbox
Alexander Bruy
alexander.bruy at gmail.com
Tue May 31 03:31:55 PDT 2016
2016-05-30 21:22 GMT+03:00 Anita Graser <anitagraser at gmx.at>:
> On Sun, May 29, 2016 at 11:54 PM, Alexandre Neto <senhor.neto at gmail.com>
> wrote:
>> Would this allow to add some outputs to the map, but not all? I don't
>> think the second screen would be very clear for users. It would be better if
>> inside a group called "Add output to the map". Actually it should be the
>> same sentence used in the save as... menu.
> +1 I also think the after screenshot is more confusing than the before since
> the user does not know what enabling the "buffer" checkbox will actually do.
> That said, I think it could be useful to allow the user to select which
> outputs should be loaded. A group as suggested by Alexandre could work.
Maybe I misunderstood, but you already can check/uncheck "Open output file"
checkboxes for every output and decide which outputs will be loaded into QGIS.
I will fix wording today.
Alexander Bruy
