[Qgis-user] [QGIS-UX] Processing UI: moving "open layer" checkbox
Anita Graser
anitagraser at gmx.at
Mon May 30 11:22:59 PDT 2016
On Sun, May 29, 2016 at 11:54 PM, Alexandre Neto <senhor.neto at gmail.com>
wrote:
> Would this allow to add some outputs to the map, but not all? I don't
> think the second screen would be very clear for users. It would be better
> if inside a group called "Add output to the map". Actually it should be the
> same sentence used in the save as... menu.
+1 I also think the after screenshot is more confusing than the before
since the user does not know what enabling the "buffer" checkbox will
actually do. That said, I think it could be useful to allow the user to
select which outputs should be loaded. A group as suggested by Alexandre
could work.
Best wishes,
Anita
> Alexandre Neto
> A dom, 29/05/2016, 16:11, Alexander Bruy <alexander.bruy at gmail.com>
> escreveu:
>> Hi all and sorry for crossposting.
>> We are thinking about improving Processing UI and one of the possible
>> enchancements is moving "Open output file" checkbox to the output
>> description,
>> see attached screenshots.
>> What do you think about this, should we proceed or keep it as is?
>> Alexander Bruy
>> QGIS-UX mailing list
>> QGIS-UX at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-ux
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160530/45ddbbb7/attachment.html>
