[Qgis-user] Query or export related layers
Jonas Dillen
jonas.dillen at natuurpunt.be
Tue May 31 06:45:50 PDT 2016
Hello,
I have related a vector shapefile (polygon) with a larger data-set from a
CSV-file, based on a common ID-field.
Whit the object-identification tool, I can now consult all matching records
from each individual polygon. So far so good.
I would like to query this joined data-set in Qgis, so I can visualise the
query-results.
Querying in the original excel would be conveniënt, but doesn't allow
map-visualisation of the results.
A possible solution would be to export the related data as a new shapefile.
Additional polygons would have to be created for the complementary
csv-records.
I can't manage to do that either.
Is there another way/plugin to handle this situation?
Greetings
Jonas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160531/db3ea01b/attachment.html>
