[Qgis-user] QAD Dimension plugin in Qgis 2.14.3 Essen (Franco Cazzola)
Franco Cazzola
F.Cazzola at amga.it
Tue May 31 09:08:09 PDT 2016
Hi
As suggested, I tried QAD plugin and dimension features using the sample project provided with the plugin.
The three dimension features work well.
May I use these features inside other QGIS project ?
I load a copy of the three layers shape files (dim_line, dim_text, dim_symbol) inside a current project.
I tried to create a new dimension style:
in the mask, I can choose and set: Line.layer, Symbol.layer but Text.layer and all others field are disable
Thanks for your contribution
Franco Cazzola
-----Messaggio originale-----
Da: gam17 at riseup.net [mailto:gam17 at riseup.net]
Inviato: martedì 24 maggio 2016 17:03
A: Franco Cazzola
Oggetto: Re: R: R: [Qgis-user] Dimension plugin in Qgis 2.10.1 Pisa
hi,
can you write in english, please ?
Anyway, after loading the sample project you have to set the current dimension style.
You can do it setting the dimstyle variable to "standard" value running the _setvar command or _dimstyle command.
After that you can run dimlinear or dimaligned command.
