[Qgis-user] Inverted polygons with draw effects in QGIS?
Chris Buckmaster
chris.buckmaster at runnymede.gov.uk
Fri Oct 28 03:17:20 PDT 2016
I have just found that it works when using the symbol draw effects, I was using the layer draw effects which didn't seem to work. What a great effect QGIS is great!
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Chris Buckmaster
Sent: 28 October 2016 11:13
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Inverted polygons with draw effects in QGIS?
Hi
I am using the inverted polygon symbol so I can symbolise outside of my polygon area which works well - I would also like to use the draw effects so I can include an outer glow and shadow around my polygon area but when I turn these on, the inverted style stops to display and reverts back to it symbolising my polygon area. I am not sure if this is an issue or just how the symbology works in QGIS?
How can I set it so that I can use the inverted polygon to style the area outside of my polygon, as well as include a glow / shadow on my polygon area so it appears to pop up from the surface?
Thanks, Chris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161028/08c20d5d/attachment.html>
