[Qgis-user] DB manager error
Gustavo Martínez gmpuljak at yahoo.com.ar
Fri Oct 28 12:09:26 PDT 2016
I'm using QGIS 2.99.0-Master rev. b2587b7 on Ubuntu 16.04 64bits.
When I tried to open a SQL query on a POSTGIS database I've got the following error while trying to open the saved connection to the database:
2016-10-28T15:58:35	1	Traceback (most recent call last):
			  File "/usr/share/qgis/python/plugins/db_manager/db_model.py", line 440, in rowCount
			    self._refreshIndex(parent, True)
			  File "/usr/share/qgis/python/plugins/db_manager/db_model.py", line 491, in _refreshIndex
			    if item.populate():
			  File "/usr/share/qgis/python/plugins/db_manager/db_model.py", line 166, in populate
			    if not connection.connect():
			  File "/usr/share/qgis/python/plugins/db_manager/db_plugins/postgis/plugin.py", line 99, in connect
			    return self.connectToUri(uri)
			  File "/usr/share/qgis/python/plugins/db_manager/db_plugins/plugin.py", line 108, in connectToUri
			    self.db = self.databasesFactory(self, uri)
			  File "/usr/share/qgis/python/plugins/db_manager/db_plugins/postgis/plugin.py", line 69, in databasesFactory
			    return PGDatabase(connection, uri)
			  File "/usr/share/qgis/python/plugins/db_manager/db_plugins/postgis/plugin.py", line 107, in __init__
			    Database.__init__(self, connection, uri)
			  File "/usr/share/qgis/python/plugins/db_manager/db_plugins/plugin.py", line 217, in __init__
			    self.connector = self.connectorsFactory(uri)
			  File "/usr/share/qgis/python/plugins/db_manager/db_plugins/postgis/plugin.py", line 110, in connectorsFactory
			    return PostGisDBConnector(uri)
			  File "/usr/share/qgis/python/plugins/db_manager/db_plugins/postgis/connector.py", line 67, in __init__
			    self.connection = psycopg2.connect(expandedConnInfo.encode('utf-8'))
			  File "/usr/lib/python3/dist-packages/psycopg2/__init__.py", line 164, in connect
			    conn = _connect(dsn, connection_factory=connection_factory, async=async)
			TypeError: argument 1 must be str, not bytes
I can load postgis layers from the same connection without problems.
What can I do?
Thanks,
Gustavo
