[Qgis-user] Still buggy...
JIA Pei jp4work at gmail.com
Wed Sep 28 13:51:49 PDT 2016
1) Just tried QGIS latest source from
http://qgis.org/downloads/qgis-latest.tar.bz2:
Still the same Error message:
[ 82%] Built target translations
> [ 82%] Generating analysis/sip_analysispart0.cpp,
> analysis/sip_analysispart1.cpp, analysis/sip_analysispart2.cpp,
> analysis/sip_analysispart3.cpp
> sip: Unable to find file "QtCore/QtCoremod.sip"
> python/CMakeFiles/python_module_qgis__analysis.dir/build.make:414: recipe
> for target 'python/analysis/sip_analysispart0.cpp' failed
> make[2]: *** [python/analysis/sip_analysispart0.cpp] Error 1
> make[2]: *** Deleting file 'python/analysis/sip_analysispart0.cpp'
> CMakeFiles/Makefile2:4165: recipe for target
> 'python/CMakeFiles/python_module_qgis__analysis.dir/all' failed
> make[1]: *** [python/CMakeFiles/python_module_qgis__analysis.dir/all]
> Error 2
> Makefile:160: recipe for target 'all' failed
> make: *** [all] Error 2
I guess it may have something to do with Python2?
2) I also tried the other way around:
http://qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu
add the following two rows to /etc/apt/sources.list
deb     http://qgis.org/debian xenial main
deb-src http://qgis.org/debian xenial main
Clearly, it requires Python2 ...
I believe for current qgis, if you need Python3 support, you've got to
rebuild everything from scratch.
So, any further suggestions??
Cheers
On Wed, Sep 28, 2016 at 11:49 AM, JIA Pei <jp4work at gmail.com> wrote:
> I actually use QGIS git from https://github.com/qgis/QGIS.git
> Should I just try the release?
> Ok... try the release now...
> On Wed, Sep 28, 2016 at 10:06 AM, Richard Duivenvoorde <
> rdmailings at duif.net> wrote:
>> On 28-09-16 12:56, JIA Pei wrote:
>> > Looks like it has something to do with
>> > QT4_WRAP_CPP?
>> > Why there is still QT4_WRAP_CPP in  src/server/CMakeLists.txt ?
>> > Weird...
>> Mmm, do not have that in my src tree anymore. Sure you have latest
>> version and all dependencies?
>> Just build in a clean tree on Debian Testing
>> Regards,
>> Richard
> Pei JIA, Ph.D.
> Email: jp4work at gmail.com
> cell in Canada:    +1 778-863-5816
> cell in China: +86 186-8244-3503
> Welcome to Vision Open
> http://www.visionopen.com
Pei JIA, Ph.D.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160928/c32028bf/attachment.html>
