[Qgis-user] Still buggy...
Jürgen E. Fischer jef at norbit.de
Wed Sep 28 15:15:06 PDT 2016
On Wed, 28. Sep 2016 at 13:51:49 -0700, JIA Pei wrote:
> 1) Just tried QGIS latest source from
> http://qgis.org/downloads/qgis-latest.tar.bz2:
> [ 82%] Built target translations
> > [ 82%] Generating analysis/sip_analysispart0.cpp,
> > analysis/sip_analysispart1.cpp, analysis/sip_analysispart2.cpp,
> > analysis/sip_analysispart3.cpp
> > sip: Unable to find file "QtCore/QtCoremod.sip"
That's in pyqt5-dev or python-qt4-dev.
> I guess it may have something to do with Python2?
Depends.  QGIS3 (master branch) requires Qt5/PyQt5/Py3.  Earlier branches
(master_2, releases) require Qt4/PyQt4/Py2.
> deb     http://qgis.org/debian xenial main
> Clearly, it requires Python2 ...
No suprise.
> I believe for current qgis, if you need Python3 support, you've got to
> rebuild everything from scratch.
No.  There are also experimental build of master now:
deb     http://qgis.org/debian-nightly-experimental xenial main
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160929/0a51e2fa/attachment.sig>
