[Qgis-user] QGIS Server cannot use port 80
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Apr 4 17:51:41 PDT 2017
Port 80 and 8080 are standard internet ports.  Almost anything using the web with http will use that port.   Can't help much with the qgis web server but yes, i am sure it can be configured to use any port but using port 80 should not be a problem.  This link should help.
http://www.itopen.it/qgis-server-python-plugins-ubuntu-setup/
https://fr.m.wikipedia.org/wiki/Liste_de_ports_logiciels
> Le 4 avr. 2017 à 19:55, Tyler Veinot-2 [via OSGeo.org] <ml-node+s1560n5315767h38 at n6.nabble.com> a écrit :
> Hi;
> All the QGIS Server tutorials I can find setup using port 80, my windows 10 PC is using port 80 for something but I cannot find out what. Is there a way to configure on port 8080?
> I tried using netstat -aon | findstr :80, and netstat -aon | findstr :80 and it gives me
>   TCP    0.0.0.0:80             0.0.0.0:0              LISTENING       2272
>   TCP    192.168.2.18:50527     151.101.1.69:80        ESTABLISHED     6476
>   TCP    192.168.2.18:50536     198.164.26.160:80      TIME_WAIT       0
>   TCP    192.168.2.18:50603     151.101.1.69:80        TIME_WAIT       0
>   TCP    192.168.2.18:50654     198.164.26.160:80      ESTABLISHED     6476
>   TCP    192.168.2.18:50656     54.243.104.69:80       ESTABLISHED     6476
>   TCP    192.168.2.18:50657     104.17.27.15:80        ESTABLISHED     6476
> But not telling me what is using the port.
> Any thoughts? Thanks ;
> Tyler
> Qgis-user mailing list
> [hidden email]
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Server-cannot-use-port-80-tp5315767.html
> To start a new topic under QGIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from QGIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-Server-cannot-use-port-80-tp5315767p5315780.html
Sent from the QGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170404/e4f62c9c/attachment.html>
