[Qgis-user] background transparency
Richard McDonnell richard.mcdonnell at opw.ie
Mon Aug 14 07:04:04 PDT 2017
Hi Brett
You can indeed, just use the Processing toolbox, just type Translate
into the search box and select the Translate Tool under GDAL.
The values you specified as transparent, can be specified under the
Nodata Value
You can also do this as part of a batch if you have a number of files,
you wish to do this for.
Hope this helps,
Richard.
On 14/08/2017 14:07, Brett Adams wrote:
> Hi Folks,
> I have a geotiff that contains a black ground in areas where there is
> no data.  The black background is made transparent within QGIS via
> “Layer Properties – Transparency”
> Can I export a new Geotiff with the black background removed?
> I’m running 2.6.1 On Windows-7.    Yes, I know it’s an old version but
> I’ve had no reason to update.  So far…
> Thanks
> *Brett Adams*
> *Spinifex-GPX*
> *0438 861 974*
> Qgis-user mailing list
*_Richard McDonnell_*
*GIS Specialist PgD GIS AssocSCSI*
*OPW FRM Data Management*
*52 Stephens Green, Dublin 2.*
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170814/98b206ee/attachment.html>
