[Qgis-user] background transparency
Richard McDonnell richard.mcdonnell at opw.ie
Mon Aug 14 07:15:53 PDT 2017
Brett,
Apologies, ive just realised your version of QGIS may not have the
processing toolbox.
You may also do this by going to *RASTER*, *Conversion *and
selecting*Translate *Its the very same tool just a different interface
Regards,
Richard
On 14/08/2017 15:04, Richard McDonnell wrote:
> Hi Brett
> You can indeed, just use the Processing toolbox, just type Translate
> into the search box and select the Translate Tool under GDAL.
> The values you specified as transparent, can be specified under the
> Nodata Value
> You can also do this as part of a batch if you have a number of files,
> you wish to do this for.
> Hope this helps,
> Richard.
> On 14/08/2017 14:07, Brett Adams wrote:
>> Hi Folks,
>> I have a geotiff that contains a black ground in areas where there is
>> no data.  The black background is made transparent within QGIS via
>> “Layer Properties – Transparency”
>> Can I export a new Geotiff with the black background removed?
>> I’m running 2.6.1 On Windows-7.    Yes, I know it’s an old version
>> but I’ve had no reason to update. So far…
>> Thanks
>> *Brett Adams*
>> *Spinifex-GPX*
>> *0438 861 974*
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> *_Richard McDonnell_*
> *GIS Specialist PgD GIS AssocSCSI*
> *OPW FRM Data Management*
> *52 Stephens Green, Dublin 2.*
> TEL: 01 6476543
> <http://www.opw.ie/>
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
TEL: 01 6476543
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170814/dcadb900/attachment.html>
