[Qgis-user] QGIS ignore the cpg files when loading shapefiles ?
Andrea Peri aperi2007 at gmail.com
Fri Dec 29 05:31:24 PST 2017
I confirm .
The setting is at application level , not at project level.
I have my desktop set to "ignore setting", but when move to qgis-server it
don't use the cpg file.
So now I'm now changing manually all the layers one by one in my project
qgis from System to the effective charset of every single shapefile to use
them on qgis-server.
A.
2017-12-29 13:58 GMT+01:00 Richard Duivenvoorde <rdmailings at duif.net>:
> On 29-12-17 13:12, Tobias Wendorff wrote:
> > Am Fr, 29.12.2017, 13:02 schrieb Richard Duivenvoorde:
> >> So the project is leading
> > Then the setting is in the wrong place. In QGIS3, it's an application
> > wide setting, not a project setting.
> Hi Tobias,
> Sorry. You are right. I was just echoing my interpretation of Paolo's
> email.
> It seems a indeed an application setting:
>  /qgis/ignoreShapeEncoding
> used here:
> https://github.com/qgis/QGIS/blob/master/src/providers/ogr/
> qgsogrprovider.cpp#L433
> In desktop defaulting to true:
> https://github.com/qgis/QGIS/blob/master/src/app/qgsoptions.cpp#L644
> I'm not familiar with how the settings/environment are created for the
> server.
> Depending the view on being it a project setting, or a application
> setting, it should be, or NOT be in the project file.
> BUT if not be in the project file, there is maybe a way (via custom
> settings?) to put this kind of stuff in the environment?
> In 3.0 and 2.18 I changed the value to false, but could not find
> anything in the project file.
> I think we should try to define this clearly:
> - should we define it a project or a application
> (?? is one server one application??) setting
> - where does the 'settings' come from for a freshly started qgisserver.
> (as normally you do not use the same server machine on which you run
> desktop)
> Regards,
> Qgis-user mailing list
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171229/4a4ebe98/attachment.html>
