[Qgis-user] maps rotated and reversed.
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sun Feb 26 10:48:05 PST 2017
You have CRS problem.  Your map is probably in a coordinate reference system that uses  x,y, but you are probably selecting a CRS that uses y,x. Ex: latitude/longitude vs long/lat. that would explain everything.
Nicolas
> Le 26 févr. 2017 à 10:33, Randal Hale [via OSGeo.org] <ml-node+s1560n5309554h35 at n6.nabble.com> a écrit :
> Make sure your CRS of the georeferencer and the CRS of QGIS are the same. I bet you're mixing stateplane/utm with WGS84 (4326).
> Randy
>> On 02/26/2017 10:04 AM, Charles Barrows wrote:
>> I am using  the Georeferencer plugin on a jpg map.  Everything goes smoothly, but the resultant map file in QGIS has been rotated 90 degrees and reversed.  The rotation is easy to handle but I can’t figure out how to reverse the reverse.  What am I doing wrong?
>> Charley
>> Qgis-user mailing list
>> [hidden email]
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Randal Hale
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 [hidden email]
> twitter:rjhale     http://about.me/rjhale
> http://www.northrivergeographic.com/introduction-to-quantum-gis
> https://www.facebook.com/NRGSInc
> [hidden email]
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/maps-rotated-and-reversed-tp5309549p5309554.html
> To start a new topic under QGIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from QGIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/maps-rotated-and-reversed-tp5309549p5309565.html
Sent from the QGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170226/9cab6360/attachment.html>
