[Qgis-user] crash on startup
Stephen Bosch
posting at vodacomm.ca
Thu Jun 1 04:53:13 PDT 2017
Hi Frank,
there seem to be problems with the Ubuntu runtime dependencies. I don't run
Ubuntu myself. If you can, try and see if it will let you use an older
version of qhull (2012.1, for example).
Otherwise have a look at this:
https://gis.stackexchange.com/questions/234010/qgis-fails-to-load/234031
Stephen
On Wed, May 31, 2017 at 10:01 PM, Frank Howell <frankmhowell at gmail.com>
wrote:
> I get the following messages piped back to the terminal when I execute
> QGIS 2.18.9 with ubuntu dependencies. I'm using Linux Mint 2.18.1 with
> Cinnamon x64 3.2.7 and kernal version 4.8.0-51 generic:
> frank at lil-jonny ~ $ qgis &
> [1] 43028
> frank at lil-jonny ~ $ Warning: loading of qgis translation failed
> [/usr/share/qgis/i18n//qgis_en_US]
> Warning: loading of qt translation failed [/usr/share/qt4/translations/
> qt_en_US]
> Warning: QCss::Parser - Failed to load file "/style.qss"
> QInotifyFileSystemWatcherEngine::addPaths: inotify_add_watch failed: No
> such file or directory
> Warning: QFileSystemWatcher: failed to add paths:
> /home/frank/.qgis2//project_templates
> Warning: QLayout: Attempting to add QLayout "" to QgsPanelWidgetStack
> "mWidgetStack", which already has a layout
> QH6248 qh_lib_check: Incorrect qhull library called. Caller uses
> reentrant Qhull while library is non-reentrant
> QH6249 qh_lib_check: Incorrect qhull library called. Size of qhT for
> caller is 8184, but for library is 2896.
> QH6255 qh_lib_check: Cannot continue. Library 'qhull 7.2.0 (2015.2
> 2016/01/18)' uses a dynamic qhT via qh_QHpointer (e.g., qhull_p.so)
> The package "qhull.bin" is installed.
> Any thoughts?
> Frank
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170601/50fd773f/attachment.html>
