[Qgis-user] Split features tool behavior
Bernhard Ströbl
bernhard.stroebl at jena.de
Tue Jun 20 00:30:21 PDT 2017
Hi Andreas,
good it works, thanks for testing.
For the tracing function (I have no idea how much work that would be,
either): You are welcome to file an enhancement ticket for this as I am
planning to overhaul the plugin once QGIS 3.0 is released.
Bernhard
Am 20.06.2017 um 09:24 schrieb Andreas Wicht:
> Hi Bernhard,
> perfect! Both works for me.
> A nice-to-have for the future would also be the utilization of the
> tracing function in case tracing is enabled.
> I can not assess how much work that would mean.
> cheers
> On 19 June 2017 at 18:05, Bernhard Ströbl <bernhard.stroebl at jena.de> wrote:
>> Hi Andreas,
>> has been fixed; split feature now uses the highlight color, too
>> Please update your plugin
>> Bernhard
>> Am 19.06.2017 um 10:05 schrieb Andreas Wicht:
>>> Hi Bernhard,
>>> I can consistently produce a python error when splitting a Multipart
>>> Feature and then clicking "No to all":
>>> UnboundLocalError: local variable 'newGeoms' referenced before assignment
>>> Traceback (most recent call last):
>>> File
>>> "C:\Users\Andreas.Wicht\.qgis2\python\plugins\DigitizingTools\tools\dtsplitfeature.py",
>>> line 139, in digitizingFinished
>>> newFeatures = dtutils.dtMakeFeaturesFromGeometries(self.editLayer,
>>> aFeat, newGeoms)
>>> Python version: 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64
>>> bit (AMD64)]
>>> QGIS version: 2.18.9 Las Palmas, 3a16a4e
>>> Is that case maybe not covered properly or should I search for causes on
>>> my end?
>>> On 19 June 2017 at 08:28, Bernhard Ströbl <bernhard.stroebl at jena.de>
>>> wrote:
>>>> Hi Andreas,
>>>> the color is currently defined in the code. I did not find any setting to
>>>> apply. AFAIK only selection color can be defined by the user, but it
>>>> might
>>>> be misleading if you have a selected feature and then have split parts
>>>> colored exactly the same. - Wait a minute I just found the "Highlight
>>>> color". That would probably work. Will check.
>>> Okay. Thank you!
>>>> Am 17.06.2017 um 13:22 schrieb Andreas Wicht:
>>>>> Hi Bernhard,
>>>>> just got to test the new version. It works now as expected.
>>>>> Thank you a lot for the good work there!
>>>>> Is the highlight color of the currently "selected" part (when you
>>>>> choose which part should form the new feature) defined in the code or
>>>>> does it use a color, which is set in the QGIS settings?
> __________ Information from ESET Mail Security, version of virus signature database 15612 (20170620) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
http://www.eset.com
