[Qgis-user] QGis server getprint request / layer order
lars lingner
gislars+list at gmail.com
Thu Jun 29 07:32:48 PDT 2017
Hello Andreas,
Am 29.06.2017 um 16:03 schrieb Neumann, Andreas:
> Hi Lars,
> Regarding @xvfb: you don't need specifically xvfb, but any XServer. xvfb
> is just one way of satisfying this requirement. Any XServer would do ...
> It is a requirement of the qt library, if you want to output to PDF.
Thanks for clarification.
> Regarding layer order:
> I had a similar issue - but it was the same layer order problem in
> GetMap and GetPrint. I am surprised that the issue only surfaces in
> GetPrint for you - are you sure?
Yes, I testet it multiple times with a clean project file and a small
set of data.
It is only the getprint request with QGis-Server which puts the polygons
on top.
> See the fix
> at https://github.com/qgis/QGIS/commit/6b5a997df578a7996dc95e93690fe0a3d24e089b
> So if you use QGIS server 2.18 which was compiled before April 18,
> please install a newer version and see if the issue is fixed for you?
I can give it a try, but I have to build a new package first. Or maybe
[1] will help, it is 2.18.9 but from 22-Jun-2017.
Since I'm using 2.18.10 from [2] I'm not sure if the patch you mentioned
should be already included here. The file date shows 24-Jun-2017.
Lars
[1]
http://qgis.org/debian-nightly-release/pool/main/q/qgis/qgis-server_2.18.9+git20170622+6cfd1a0+26zesty_amd64.deb
[2]
http://qgis.org/debian/pool/main/q/qgis/libqgis-server2.18.10_2.18.10+26zesty_amd64.deb
