[Qgis-user] QGis server getprint request / layer order
Neumann, Andreas
a.neumann at carto.net
Thu Jun 29 07:41:16 PDT 2017
hm - then it sounds like a different issue to what I had.
Can you please create an issue report with a sample project and steps to
reproduce?
Andreas
On 2017-06-29 16:32, lars lingner wrote:
> Hello Andreas,
> Am 29.06.2017 um 16:03 schrieb Neumann, Andreas:
>> Hi Lars,
>> Regarding @xvfb: you don't need specifically xvfb, but any XServer. xvfb
>> is just one way of satisfying this requirement. Any XServer would do ...
>> It is a requirement of the qt library, if you want to output to PDF.
> Thanks for clarification.
>> Regarding layer order:
>> I had a similar issue - but it was the same layer order problem in
>> GetMap and GetPrint. I am surprised that the issue only surfaces in
>> GetPrint for you - are you sure?
> Yes, I testet it multiple times with a clean project file and a small
> set of data.
> It is only the getprint request with QGis-Server which puts the polygons
> on top.
>> See the fix
>> at https://github.com/qgis/QGIS/commit/6b5a997df578a7996dc95e93690fe0a3d24e089b
>> So if you use QGIS server 2.18 which was compiled before April 18,
>> please install a newer version and see if the issue is fixed for you?
> I can give it a try, but I have to build a new package first. Or maybe
> [1 [1]] will help, it is 2.18.9 but from 22-Jun-2017.
> Since I'm using 2.18.10 from [2 [2]] I'm not sure if the patch you mentioned
> should be already included here. The file date shows 24-Jun-2017.
> Lars
> [1]
> http://qgis.org/debian-nightly-release/pool/main/q/qgis/qgis-server_2.18.9+git20170622+6cfd1a0+26zesty_amd64.deb
> [2]
> http://qgis.org/debian/pool/main/q/qgis/libqgis-server2.18.10_2.18.10+26zesty_amd64.deb
> Qgis-user mailing list
Links:
[1]
[2]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170629/49e597de/attachment.html>
