[Qgis-user] QGis server getprint request / layer order
lars lingner
gislars+list at gmail.com
Thu Jun 29 09:12:13 PDT 2017
Hello,
for reference here is the ticket: https://issues.qgis.org/issues/16769
Lars
Am 29.06.2017 um 16:41 schrieb Neumann, Andreas:
> hm - then it sounds like a different issue to what I had.
> Can you please create an issue report with a sample project and steps to
> reproduce?
> Andreas
> On 2017-06-29 16:32, lars lingner wrote:
>> Hello Andreas,
>> Am 29.06.2017 um 16:03 schrieb Neumann, Andreas:
>>> Hi Lars,
>>> Regarding @xvfb: you don't need specifically xvfb, but any XServer. xvfb
>>> is just one way of satisfying this requirement. Any XServer would do ...
>>> It is a requirement of the qt library, if you want to output to PDF.
>> Thanks for clarification.
>>> Regarding layer order:
>>> I had a similar issue - but it was the same layer order problem in
>>> GetMap and GetPrint. I am surprised that the issue only surfaces in
>>> GetPrint for you - are you sure?
>> Yes, I testet it multiple times with a clean project file and a small
>> set of data.
>> It is only the getprint request with QGis-Server which puts the polygons
>> on top.
>>> See the fix
>>> at
>>> https://github.com/qgis/QGIS/commit/6b5a997df578a7996dc95e93690fe0a3d24e089b
>>> So if you use QGIS server 2.18 which was compiled before April 18,
>>> please install a newer version and see if the issue is fixed for you?
>> I can give it a try, but I have to build a new package first. Or maybe
>> [1
>> <http://qgis.org/debian-nightly-release/pool/main/q/qgis/qgis-server_2.18.9+git20170622+6cfd1a0+26zesty_amd64.deb>]
>> will help, it is 2.18.9 but from 22-Jun-2017.
>> Since I'm using 2.18.10 from [2
>> <http://qgis.org/debian/pool/main/q/qgis/libqgis-server2.18.10_2.18.10+26zesty_amd64.deb>]
>> I'm not sure if the patch you mentioned
>> should be already included here. The file date shows 24-Jun-2017.
>> Lars
>> [1]
>> [2]
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
