[Qgis-user] API REQUIRED from OSM cycle map
Frederico dos Santos Soares
fssunb at gmail.com
Fri Mar 24 11:09:53 PDT 2017
Hi Bernd,
I'd tried the QuickMapServices. Works perfectly.
Sometimes I forget to think "easy", and just go by the hard way.
Thank you.
Date: Fri, 24 Mar 2017 16:49:18 +0100
From: "Bernd Vogelgesang" <bernd.vogelgesang at gmx.de>
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] API REQUIRED from OSM cycle map
Message-ID: <op.yxl3kgk1l2i25i at bernd-pc>
Content-Type: text/plain; charset="utf-8"; Format="flowed";
DelSp="yes"
is there a specific need for you to use the OpenLayers plugin?
Maybe you could try to add the service to the QuickMapServices plugin more
easily (under settings)
Cheers
Bernd
2017-03-24 8:10 GMT-03:00 Frederico dos Santos Soares <fssunb at gmail.com>:
> Hi everybody I'm having some problems with the OpenStreetMap's services in
> openlyers's plugin.
> In fact the problem is the 'API Require Key' in cyclemap.
> I did my login in Thunderforest and with the URL (with my token) given by
> Thunderforest's site, I substituted the URL in OpenLyers's files (xml and
> html files).
> This is an exemple of URL that I used:
> https://{s}.tile.thunderforest.com/cycle/{z}/{x}/{y}.png?apikey=cc63d6d.
> <http://tile.thunderforest.com/cycle/%7Bz%7D/%7Bx%7D/%7By%7D.png?apikey=cc63d6d.>
> I alredy tried remove the {s} from URL
> I'm using QGIS2.14.
> Someone had passed thru the same thing and solve the problem?
> Thanks.
> Geógrafo
> 55 61 8416 0105
> fssunb at gmail.com
Geógrafo
55 61 8416 0105
fssunb at gmail.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170324/5e6f8beb/attachment.html>
