[Qgis-user] Problem with node tool in 'testing'
DelazJ
delazj at gmail.com
Thu May 4 08:23:37 PDT 2017
Sorry but I'm not sure to understand what you are reporting:
- the tool does no longer work?
- or the tool behaves differently? In this case, if you are testing QGIS3,
yes the tool has changed and reading
https://github.com/qgis/QGIS-Enhancement-Proposals/issues/69 may help you
understand the new features.
Hope that helps,
Harrissou
2017-05-04 14:57 GMT+02:00 Torbjorn W <t at persby.se>:
> hello,
> I have a map with a (vector) track. Before, I used the node tool to edit:
> clicked on a track to select it, then on a point and drag to move it, as
> usual.
> Since about two weeks ago or so, when I click on a point in the track, it
> does
> not convert to a square and allow me to move it, it justs goes from a red
> dot to
> a bigger red dot.
> This is 'testing', last update, so things stops to work sometimes, but
> usually
> they starts to work again the day after or so. But not this time. Anyony
> who has any idéa what
> has happened? It may, of course, be the case that I have clicked on
> soething I
> should not, or maybe the function of the node tool has changed?
> thanks,
> Torbjörn W
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170504/b9b4e117/attachment.html>
