[Qgis-user] QGIS web client & Joins
Neumann, Andreas a.neumann at carto.net
Fri May 5 01:37:08 PDT 2017
Hi Julian,
The QGIS bug/issue system was recently migrated. If it was an issue on
QGIS web client I, it was removed. QGIS web client I is not being worked
on any more. It is succeeded by QGIS web client II and the issue queue
of that is at https://github.com/qgis/qwc2-demo-app/issues
Andreas
On 2017-05-05 10:30, BraDypUS. Communicating Cultural Heritage wrote:
> Yes, I had a preview of the issue in Google, but the ussue itself has been (re)moved.
> I'll check bettee the wms service.
> Thank you
> Il 05 Mag 2017 10:26 AM, "Neumann, Andreas" <a.neumann at carto.net> ha scritto:
> Hi Julian,
> The issue you mention doesn't exist.
> I doubt that this is a QGIS web client issue. Did you test with QGIS as WMS client? Does it work there?
> If it doesn't work there either, than this is can most likely be a "path-issue" (absolute vs. relativ paths) or a QGIS server issue.
> Andreas
> On 2017-05-05 08:53, Julian Bogdani wrote:
> Hello,
> I'm having an issue with joins in a webGIS project using Qgis as a map server and Qgis web client.
> I have an external table (sqlite) correctly joined to a shape file on my desktop project, but the joined attributes do not show on the web project. I thought the sqlite could be the problem so I tried with CSV and DBF, so I guess it's not a file type problem.
> Are joins supported? I did not find any docs on this. I see somebody else had this problem before, but the qgis issue had been moved (https://hub.qgis.org/issues/5324 [1])..
> Thank you
> Julian Bogdani
> jbogdani at gmail.com
> http://bradypus.net
> Qgis-user mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user [2]
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user [2]
Links:
[1] https://hub.qgis.org/issues/5324
[2] https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170505/97406c9a/attachment.html>
