[Qgis-user] QGIS web client & Joins
Julian Bogdani
jbogdani at gmail.com
Fri May 5 02:25:16 PDT 2017
Thank you,
Actually the was is working correctly and all attributes are available, both shape file attributes and joined ones.
It seems then it is a qgs web client problem.
Probably I should upgrade to the II version…
Any hint?
BraDypUS
Communicating Cultural Heritage
http://bradypus.net
info at bradypus.net <mailto:info at bradypus.net>
bradypus at pec.it
> On 5 May 2017, at 10:37, Neumann, Andreas <a.neumann at carto.net> wrote:
> Hi Julian,
> The QGIS bug/issue system was recently migrated. If it was an issue on QGIS web client I, it was removed. QGIS web client I is not being worked on any more. It is succeeded by QGIS web client II and the issue queue of that is at https://github.com/qgis/qwc2-demo-app/issues <https://github.com/qgis/qwc2-demo-app/issues>
> Andreas
> On 2017-05-05 10:30, BraDypUS. Communicating Cultural Heritage wrote:
>> Yes, I had a preview of the issue in Google, but the ussue itself has been (re)moved.
>> I'll check bettee the wms service.
>> Thank you
>> Il 05 Mag 2017 10:26 AM, "Neumann, Andreas" <a.neumann at carto.net <mailto:a.neumann at carto.net>> ha scritto:
>> Hi Julian,
>> The issue you mention doesn't exist.
>> I doubt that this is a QGIS web client issue. Did you test with QGIS as WMS client? Does it work there?
>> If it doesn't work there either, than this is can most likely be a "path-issue" (absolute vs. relativ paths) or a QGIS server issue.
>> Andreas
>> On 2017-05-05 08:53, Julian Bogdani wrote:
>> Hello,
>> I'm having an issue with joins in a webGIS project using Qgis as a map server and Qgis web client.
>> I have an external table (sqlite) correctly joined to a shape file on my desktop project, but the joined attributes do not show on the web project. I thought the sqlite could be the problem so I tried with CSV and DBF, so I guess it's not a file type problem.
>> Are joins supported? I did not find any docs on this. I see somebody else had this problem before, but the qgis issue had been moved (https://hub.qgis.org/issues/5324 <https://hub.qgis.org/issues/5324>)..
>> Thank you
>> Julian Bogdani
>> jbogdani at gmail.com <mailto:jbogdani at gmail.com>
>> http://bradypus.net <http://bradypus.net/>
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170505/dc1d5eca/attachment.html>
