[Qgis-user] Moving selected feature to the top of attribute table does not seem to work in 2.18.7
Luigi Pirelli luipir at gmail.com
Thu May 18 01:12:57 PDT 2017
fixed during the hackfest on current 2.18 code (you have to wait for
2.18.8... or update to the latest 2.18 code not the tagged release
version)
https://github.com/qgis/QGIS/pull/4306
and 3.0
https://github.com/qgis/QGIS/pull/4444
btw there are some simple workaround to fix temporarly waiting the patch release
workaround 1) in the attribute table, apply a sort on some column =>
apply sortOnTop
workaround 2) in your project xml file you should have a tag as:
<attributetableconfig ... sortOrder="<someValue>" >
in your case <someValue> is something different from 0 (Ascending) or
1 (Descending)... fix it and sortOnTop will be back :)
btw, pelase let me knwo what value is in <someValue>, because is not
clear who's set it to a strange value (probably the composer)
cheers
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 18 May 2017 at 10:03, Hernán De Angelis <dhdeangelis at gmail.com> wrote:
> Hi
> Yesterday I compiled from source QGIS 2.18.7 in openSUSE Leap 42.2 Linux.
> Everything went fine and there were no problems with the compilation.
> However, when using the new installation I realized that the function that
> allows to move the attribute row of a selected feature to the top of the
> attribute table does not seem to work. This problem was not present in my
> previously installed version (2.18.6), nor in another machine I use (QGIS
> 2.14.2, Windows 7) using the same data. I wonder if any other users are
> experiencing this in 2.18.7, or there is just something wrong with my
> particular installation.
> Regards,
> Hernán
> Qgis-user mailing list
