[Qgis-user] Spatial join with QGIS 2.18.6
Martin Bain Martin.Bain at lismore.nsw.gov.au
Mon Sep 4 21:53:39 PDT 2017
I had this issue too - it went away after I uninstalled the "QGIS2compat" plugin.
Martin.
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jan-Eric Oskarsson
Sent: Tuesday, 5 September 2017 11:46 AM
To: 'Parodi Ulderica' <Ulderica.Parodi at regione.liguria.it>; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Spatial join with QGIS 2.18.6
Hi Ulderica!
I don't think you are doing anything wrong.
I tried to install refFunctions to but it seems as the refFunctions plugin is broken. Maybe it's not updated for the latest QGIS versions.
I tried to find this Pluginbuilders ,Enrico Ferreguti, email-address, to report this problem to him, but can't find it. Maybe someone else can find it.
/Jan-Eric
Från: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] För Parodi Ulderica
Skickat: den 4 september 2017 18:33
Till: 'qgis-user at lists.osgeo.org' <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>
Ämne: [Qgis-user] Spatial join with QGIS 2.18.6
Today I tried to install the plugin for spatial joins but I can't install the needed refFunctions plugin because during installation it tells me that the plgin is corrupt. The python message is: cannot import name uic.
What am I doing wrong?
Can you please give me a hint?
Thanks,
Ulderica
This email is intended for the named recipient only.  The information it contains may be confidential.  If you are not the intended recipient you must not reproduce or distribute any part of this email, disclose its contents to any other party or take any action in reliance on it.  If you have received this email in error, please contact the sender immediately and delete the message.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170905/531068d7/attachment.html>
