[Qgis-user] Spatial join with QGIS 2.18.6
Jan-Eric Oskarsson jan-eric at kregis.se
Tue Sep 5 00:09:25 PDT 2017
Hi!
Thats correct, it went away after I uninstalled the QGIS2Compat plugin for
me too!
/Jan-Eric
Från: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] För Martin Bain
Skickat: den 5 september 2017 06:54
Till: qgis-user at lists.osgeo.org
Ämne: Re: [Qgis-user] Spatial join with QGIS 2.18.6
I had this issue too – it went away after I uninstalled the “QGIS2compat”
plugin.
Martin.
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of
Jan-Eric Oskarsson
Sent: Tuesday, 5 September 2017 11:46 AM
To: 'Parodi Ulderica' <Ulderica.Parodi at regione.liguria.it
<mailto:Ulderica.Parodi at regione.liguria.it> >; qgis-user at lists.osgeo.org
<mailto:qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Spatial join with QGIS 2.18.6
Hi Ulderica!
I don’t think you are doing anything wrong.
I tried to install refFunctions to but it seems as the refFunctions plugin
is broken. Maybe it’s not updated for the latest QGIS versions.
I tried to find this Pluginbuilders ,Enrico Ferreguti, email-address, to
report this problem to him, but can’t find it. Maybe someone else can find
it.
/Jan-Eric
Från: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] För Parodi
Ulderica
Skickat: den 4 september 2017 18:33
Till: 'qgis-user at lists.osgeo.org' <qgis-user at lists.osgeo.org
<mailto:qgis-user at lists.osgeo.org> >
Ämne: [Qgis-user] Spatial join with QGIS 2.18.6
Today I tried to install the plugin for spatial joins but I can’t install
the needed refFunctions plugin because during installation it tells me that
the plgin is corrupt. The python message is: cannot import name uic.
What am I doing wrong?
Can you please give me a hint?
Thanks,
Ulderica
This email is intended for the named recipient only. The information it
contains may be confidential. If you are not the intended recipient you must
not reproduce or distribute any part of this email, disclose its contents to
any other party or take any action in reliance on it. If you have received
this email in error, please contact the sender immediately and delete the
message.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170905/1b0fe4bb/attachment.html>
